メインコンテンツにスキップ
Linksys WAP54g Bottom Casing/Motherboard Replacement
必要な工具と部品
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: 手順 1、 1の画像 1
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 2、 1の画像 1
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 4、 1の画像 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 5、 1の画像 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 6、 1の画像 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 7、 2の画像 1 Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 7、 2の画像 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 8、 2の画像 1 Linksys WAP54g Bottom Casing/Motherboard Replacement: 手順 8、 2の画像 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 手順 9、 2の画像 1 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 手順 9、 2の画像 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
終わりに
After the motherboard is isolated component level repairs can be made.
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Mathew Fuller
メンバー登録日: 10/04/11
146 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G21
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,582
