はじめに
Faulty power ports can result in loss of power to your device. This guide will show you how to identify and replace a dysfunctional power port on your router.
Make sure you are in a well ventilated area at room temperature with the proper safety equipment when soldering.
必要な工具と部品
Locate the power port on both sides of the motherboard.
The power port on the top side is in a rectangular black casing.
Identify the three prongs where the power port is soldered to on the reverse side.
Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
Use a black spudger to gently separate the power port from the motherboard
2 の人々がこのガイドを完成させました。
