メインコンテンツにスキップ
Light and Motion SOLA VIDEO2000 battery Replacement
必要な工具と部品
  1. Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: 手順 1、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: 手順 1、 2の画像 2
    • This step may need some force applied to unscrew the lamp head cap.
  2. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: 手順 2、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: 手順 2、 2の画像 2
    • Gently pull the light head by the PCB, not the plastic cover
    • Take note how the light head connector is guided to the PCB connector, all through the plastic cover guide.
  3. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: 手順 3、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: 手順 3、 2の画像 2
    • Gently remove the plastic cover guide
    • Take note of the cable management. It will ease the reassembly
  4. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: 手順 4、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: 手順 4、 2の画像 2
    • Gently shake the lamp and let the battery and PCB slide in your hand
    • Take note of the location where the PCB will have to slide-in during reassembly
  5. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: 手順 5、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: 手順 5、 2の画像 2
    • Gently remove the o-ring, clean it and apply o-ring grease
    • Clean the o-ring seats, both on the body and the metallic cap.
  6. Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: 手順 6、 2の画像 1 Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: 手順 6、 2の画像 2
    • Gently disconnect the battery from the PCB
    • Avoid touching the metallic strips (humidity sensor, to detect flooding) If it happens, gently wipe it with a dry, non abrasive, cloth
    • Connect the new battery
終わりに
Use some force to screw back the lamp head cap, but not too much!
After 3 full discharge cycles, the higher capacity battery will give 65min light at full brightness (vs 45 min with the original battery)
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ralf
メンバー登録日: 06/28/13
363 ポイント
2のガイドは作成済み
3件のガイドコメント
Bonjour,
Le pack de batteries est cher pour 2 18650.
Y a t il un moyen de faire autrement ?
jpdupin - 返信
C'est pas faux, mais les packs d'accus sont généralement appairés par pièces aux caractéristiques aussi semblables que possible.
Il faut sinon démonter le pack d'origine, et récupérer le PCB... cela demande plus d'outillage et de matériel, et il faudra prendre garde à commander des accus avec languettes à souder (à moins de disposer d'un poste de soudure par points).
Pour qui a le temps et les compétences, ça peut effectivement valoir la peine...
ralf - 返信
Do these batteries also work for the Sola Dive light 800?
Hruijs - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 114
今までの合計 4,240
