メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lifetime 4-Foot Adjustable Table Leg Replacement
必要な工具と部品
  1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 手順 1、 3の画像 1 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 手順 1、 3の画像 2 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 手順 1、 3の画像 3
    • Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
    • Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
  2. Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 2、 3の画像 1 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 2、 3の画像 2 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 2、 3の画像 3
    • Clean any glue or adhesive from the braces and hinges before putting it into place.
    • It’s important to clear the screw holes of any material, so that the screws can fit without obstruction.
  3. Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 3、 3の画像 1 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 3、 3の画像 2 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 3、 3の画像 3
    • Align the screw holes of the braces with the new leg by inserting it into the frame.
    • While aligning, make sure the new leg fits into the frame slots.
  4. Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 4、 3の画像 1 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 4、 3の画像 2 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 4、 3の画像 3
    • Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
  5. Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 5、 3の画像 1 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 5、 3の画像 2 Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 5、 3の画像 3
    • Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
  6. Lifetime 4-Foot Adjustable Table Leg Replacement: 手順 6、 1の画像 1
    • Test out the table by unfolding it, and setting it up in a standing position.
    • If the leg is not aligned properly, has loose screws, or missing some screws, make the proper adjustments before using it.
終わりに
作成者
1人の作成者と共同作成されました。
Aphason Aberham
メンバー登録日: 09/11/23
133 ポイント
1ガイドが承認済み
チーム
York University, Team 1-1, O'Regan Fall 2023 York University, Team 1-1, O'Regan Fall 2023人のメンバー
YORK-O'REGAN-F23S1G1
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 84
今までの合計 1,443
