メインコンテンツにスキップ
LifePrint 3x4.5 Charging Port Replacement
必要な工具と部品
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: 手順 1、 1の画像 1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: 手順 2、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: 手順 3、 1の画像 1
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: 手順 4、 1の画像 1
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
終わりに
作成者
2人の作成者と共同で作成されました。
Jacqueline Broderick
メンバー登録日: 11/05/19
341 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 UMass Dartmouth, Team S1-G2, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 331
