はじめに
The charging port is used to charge the LifePrint 3x4.5 and is an essential working component of the printer. The port is a micro usb c port.
必要な工具と部品
Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
Pull the cover with the LP logo up to separate it from the rest of the printer.
Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
Use an opening tool to remove the inner cover from the printer.
Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
After the solder is removed use the tweezers to remove the port from the circuit board.
