メインコンテンツにスキップ
Lezyne Micro Drive Battery Replacement
必要な工具と部品
  1. Lezyne Micro Drive Battery Replacement, Battery: 手順 1、 1の画像 1
    • Mount the light in between a 11mm socket and 22 socket like so in a vice.
  2. Lezyne Micro Drive Battery Replacement: 手順 2、 1の画像 1
    • Slowly clamp, the clear light cover will push in. There is quite a lot of resistance.
  3. Lezyne Micro Drive Battery Replacement: 手順 3、 1の画像 1
    • Keep on going until the resistance fades. The light cover will be depressed as shown. and the electronics will just fall out.
  4. Lezyne Micro Drive Battery Replacement: 手順 4、 3の画像 1 Lezyne Micro Drive Battery Replacement: 手順 4、 3の画像 2 Lezyne Micro Drive Battery Replacement: 手順 4、 3の画像 3
    • You can see where the electronics slides into.
    • You can see how it is held in with friction from the raised plastic bevel. If you wish to make it easier to disassemble, file the friction bevel down. Don't file down the keying semi circular bevel.
    • The last picture shows the plastic filed down.
終わりに
To reassemble your device, just put it back together.
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
graham
メンバー登録日: 08/21/13
350 ポイント
1ガイドが承認済み
30 件のコメント
Thanks just repaired my Lezyne Macro Drive front light. Light would flicker, just needed to re-solder the top left resistor shown in step 4.
richard taylor - 返信
Thanks to your instruction I was able to fix my lezyne micro drive which had denied to work after short-circuiting the charging leads by accident. Just cut the battery and reconnected it - light was working again! Worked out nicely!
Thanks!
mongo - 返信
Is it a 123 cell it takes? I will do this when I visit my father as he has a large vice. Thanks for the guide!
Aerotec - 返信
Yes a "CR-123" cell 3V lithium ion
graham -
you can just push the electronics and battery out with your thumb. Usually the issue with these batteries is the battery contact gets slightly corroded. Clean it with battery cleaner, and twist the battery a bit for a new and clean connection.
scotdferguson - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 79
今までの合計 35,453
