メインコンテンツにスキップ
Lexmark T650 Fuser Roller Replacement
必要な工具と部品
    • A damaged pressure roller leads to paper jams.
    • A damaged non-stick coating on the heated roller causes dark marks and double images. Toner that sticks to the non stick coating on the heated roller makes an after-image or marks 94mm (3.7 inches) below the original dark print.
  1. Lexmark T650 Fuser Roller Replacement, Remove front cover: 手順 2、 1の画像 1
    • Remove these two 6mm Philips #2 screws then remove the front cover
  2. Lexmark T650 Fuser Roller Replacement, Remove top cover: 手順 3、 2の画像 1 Lexmark T650 Fuser Roller Replacement, Remove top cover: 手順 3、 2の画像 2
    • Remove these two 6mm #2 screws from the two ends of the heating element and carefully withdraw the glass heating element.
    • The glass heating element is shown in the second picture.
    • Remove these two 6mm #2 screws attaching the top cover.
    • Remove this screw attaching the red power cable.
    • Unplug the pair of yellow wires and unhook them from the hooks tucking them in place.
    • The top cover can now be removed.
  3. Lexmark T650 Fuser Roller Replacement, Release the springs: 手順 4、 2の画像 1 Lexmark T650 Fuser Roller Replacement, Release the springs: 手順 4、 2の画像 2
    • Insert a wedge under each of the two spring support arms to lift the two springs.
    • The wedges should remain in place while the fuser unit is being stored. Otherwise the pressure from top roller will make a permanent indentation in the soft pressure roller.
    • The second picture shows a suitable wedge. This example was made from a toothbrush handle.
  4. Lexmark T650 Fuser Roller Replacement, Remove paper guide: 手順 5、 2の画像 1 Lexmark T650 Fuser Roller Replacement, Remove paper guide: 手順 5、 2の画像 2
    • gently bend this paper guide to remove it.
  5. Lexmark T650 Fuser Roller Replacement, Remove top roller: 手順 6、 3の画像 1 Lexmark T650 Fuser Roller Replacement, Remove top roller: 手順 6、 3の画像 2 Lexmark T650 Fuser Roller Replacement, Remove top roller: 手順 6、 3の画像 3
    • Use circlip pliers to remove the circlip attaching the cogwheel to the top roller.
    • Slide this metal catch upwards to release the bearing from its holder. Remove the bearing.
    • The top roller can now be removed.
    • The red pressure roller is now visible with its bearings resting in the holder at each end.
  6. Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: 手順 7、 2の画像 1 Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: 手順 7、 2の画像 2
    • The pressure roller can now be lifted out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
David42
メンバー登録日: 02/11/18
1,468 ポイント
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 41
今までの合計 1,695
