はじめに
This USB cable allows the printer to be connected to your computer.
  1. Locate data USB cable.
    • Locate data USB cable.
  2. Locate the end of the cable that plugs into the printer.
    • Locate the end of the cable that plugs into the printer.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent. Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
    • Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
  5. Locate the USB end of the cable. Insert that end into your computer.
    • Locate the USB end of the cable. Insert that end into your computer.
まとめ
Once the USB cable is installed, you should be able to print documents from your computer.
2 の人々がこのガイドを完成させました。
Raymond
メンバー登録日: 2013年01月15日
42 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G38
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 438
