はじめに
The adapter connects the power chord to the printer.
  1. Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
    • Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
    • Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
  4. Firmly push adapter in until you hear a click.
    • Firmly push adapter in until you hear a click.
まとめ
The adapter should be securely inserted into the back end of the printer and be ready for use.
ある他の人がこのガイドを完成しました。
Raymond
メンバー登録日: 2013年01月15日
42 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G38
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 706
