はじめに
This guide will show how to replace the Whammy Bar. The whammy bar controls a feature in the game that increases the points while playing.
ツール
パーツ
パーツは指定されていません。
Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
Push level, this will detach the back of the guitar from the front.
Carefully remove the back of the body
The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
The neck connector may be stuck to the back so be sure to detach it before fully pulling
Carefully remove whammy bar from its slot, it should slide out easily.
Make sure the wires are not cut or damaged or it may need replacement.
Remove the two screws with a philips head screwdriver. Each screw is 0.8 cm.
Slide the other plastic pieces off the metal piece so all pieces are separate. Each piece will be given a number and color to make repair easier.
Whammy Bar
Plastic piece 1
Plastic piece 2
Plastic piece 3 and 4
Plastic piece 5
Metal piece
Connect metal piece to plastic piece 5 and make sure the metal prongs fit into the holes for them.
Next slide plastic piece 2 on the metal piece and make sure the three stubs are on the upper half.
Then, make sure the metal piece holes and the plastic piece holes match up and screw them in place with the Philips head screw driver.
2 の人々がこのガイドを完成させました。
コメント1件
Took me half an hour to find a working guide after messing up my whammy bar after taking the guitar apart. Thank you so much for this I was so lost
