メインコンテンツにスキップ
Lenovo Z40-70 Hard Drive Replacement
必要な工具と部品
  1. Lenovo Z40-70 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Close the laptop screen and flip the laptop bottom-side up.
    • Make sure the surface you are working on is dry and away from liquids and fire.
  2. Lenovo Z40-70 Hard Drive Replacement: 手順 2、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 2、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 2、 3の画像 3
    • Slide the left battery lock to the left.
    • When it is in the unlock position, you will see red underneath the lock.
    • Slide the right lock to the right.
    • The battery case will detach from the laptop.
    • Separate the battery from the laptop.
  3. Lenovo Z40-70 Hard Drive Replacement: 手順 3、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 3、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 3、 3の画像 3
    • Use a Phillips #00 screwdriver to remove two 4 mm screws along the opposite edge of the laptop.
    • Gently slide off the back cover to reveal the hard drive.
  4. Lenovo Z40-70 Hard Drive Replacement: 手順 4、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 4、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 4、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws that secure the hard drive to the laptop.
    • Slide the hard drive out from the port.
  5. Lenovo Z40-70 Hard Drive Replacement: 手順 5、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 5、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 5、 3の画像 3
    • Use a Phillips #00 screwdriver to remove four 3 mm screws from the metal drive attachments.
    • There should be two screws on each of the long sides of the drive attachments.
  6. Lenovo Z40-70 Hard Drive Replacement: 手順 6、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 6、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 6、 3の画像 3
    • Screw the metal attachments into the new drive.
    • Make sure the holes in the attachments align with the holes in the drive.
    • Insert the drive back into its slot and slide it into the port.
    • Secure the hard drive with three PH #00 screws.
  7. Lenovo Z40-70 Hard Drive Replacement: 手順 7、 3の画像 1 Lenovo Z40-70 Hard Drive Replacement: 手順 7、 3の画像 2 Lenovo Z40-70 Hard Drive Replacement: 手順 7、 3の画像 3
    • Slide the cover back in place and secure with two PH #00 screws.
    • Connect the heart-shaped indents to the raised parts of the battery compartment.
    • Flip the red switch to the right to lock the battery in place.
終わりに
After completing the replacement, boot up your laptop as it is ready to use.
作成者
1人の作成者と共同作成されました。
Licia
メンバー登録日: 01/11/24
145 ポイント
1ガイドが承認済み
チーム
York University, Team 2-27, O'Regan Winter 2024 York University, Team 2-27, O'Regan Winter 2024人のメンバー
YORK-O'REGAN-W24S2G27
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 64
