メインコンテンツにスキップ
はじめに
This guide will show you how to remove the SSD of the Lenovo Yoga-900-13ISK2. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
パーツ
パーツは指定されていません。
  1. Flip the laptop so that the back panel is facing up. Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Gently lift the back cover off of the laptop.
    • Gently lift the back cover off of the laptop.
  3. Push the black battery cable towards the battery to disconnect it. Push the black battery cable towards the battery to disconnect it.
    • Push the black battery cable towards the battery to disconnect it.
  4. Remove the six #0 3.8mm Phillips screws from the battery. Remove the six #0 3.8mm Phillips screws from the battery.
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Gently lift the battery out of the laptop chassis.
    • Gently lift the battery out of the laptop chassis.
  6. Remove the one #0 2.9mm Phillips screw from the SSD. Remove the one #0 2.9mm Phillips screw from the SSD.
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  7. Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
終わりに
3 の人々がこのガイドを完成させました。
Nathan Lui
メンバー登録日: 2017年04月10日
818 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S13-G6, Forte Spring 2017 Cal Poly, Team S13-G6, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G6
4 メンバー
6のガイドは作成済み
3 件のコメント
For my Yoga 900 I needed a T5 Torx screw driver. Otherwise spot on.
Dan Benze - 返信
thanks for the info, what about the data from the original drive??
Jos Chan - 返信
Why did you remove the battery? Was it necessary?
Chris Horsfall - 返信
コメントを追加
統計データを表示:
過去 24時間: 6
過去 7 日: 31
過去 30 日: 164
今までの合計 4,613
