メインコンテンツにスキップ
はじめに
This guide will show you how to remove the battery in your Lenovo Yoga-900-13ISK2.
パーツ
パーツは指定されていません。
  1. Flip the laptop so that the back panel is facing up. Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Gently lift the back cover off of the laptop.
    • Gently lift the back cover off of the laptop.
  3. Push the black battery cable towards the battery to disconnect it. Push the black battery cable towards the battery to disconnect it.
    • Push the black battery cable towards the battery to disconnect it.
  4. Remove the six #0 3.8mm Phillips screws from the battery. Remove the six #0 3.8mm Phillips screws from the battery.
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Gently lift the battery out of the laptop chassis.
    • Gently lift the battery out of the laptop chassis.
終わりに
5 の人々がこのガイドを完成させました。
Nathan Lui
メンバー登録日: 2017年04月10日
818 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S13-G6, Forte Spring 2017 Cal Poly, Team S13-G6, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G6
4 メンバー
6のガイドは作成済み
2 件のコメント
It is not a T6 driver. It is T5.
Rob Diefenbach Jr - 返信
can you recommend a good place to purchase a replacement battery?
Rodney Gooding - 返信
コメントを追加
統計データを表示:
過去 24時間: 11
過去 7 日: 61
過去 30 日: 343
今までの合計 9,502
