メインコンテンツにスキップ
Lenovo Yoga Tab 3 8 Wifi Module Replacement
必要な工具と部品
  1. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 手順 1、 3の画像 1 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 手順 1、 3の画像 2 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 手順 1、 3の画像 3
    この手順で使用する道具:
    購入する
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 2、 1の画像 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 3、 3の画像 1 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 3、 3の画像 2 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 3、 3の画像 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Wifi Module: 手順 4、 1の画像 1
    • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
  5. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 5、 2の画像 1 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Locate the copper foil holding down the WiFi module near where the grey wire connects. Use tweezers to carefully lift up and separate the copper foil.
  6. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 6、 1の画像 1
    • Remove the three 2mm screws holding the wifi module to the device using a PH00 screwdriver.
  7. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 7、 2の画像 1 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 手順 7、 2の画像 2
    • Remove the grey wire from the channel holding it by gently lifting it up with your fingers.
    • Lift the wifi module out of the device with your fingers.
終わりに
作成者
5人の作成者と共同で作成されました。
Nicklaus Krems
メンバー登録日: 09/25/17
1,049 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S16G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 1,755
