メインコンテンツにスキップ
Lenovo Yoga Tab 3 8 Motherboard Replacement
必要な工具と部品
  1. Lenovo Yoga Tab 3 8 Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Lenovo Yoga Tab 3 8 Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 3、 3の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 3、 3の画像 2 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 3、 3の画像 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Motherboard Replacement, Motherboard: 手順 4、 3の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement, Motherboard: 手順 4、 3の画像 2 Lenovo Yoga Tab 3 8 Motherboard Replacement, Motherboard: 手順 4、 3の画像 3
    この手順で使用する道具:
    • With the device oriented screen side down and hinge opposite of you, locate the silver metal bracket on the top left covering the battery and camera connections. Remove the two 3mm screws with a PH00 screwdriver.
    • Remove the bracket with your fingers to reveal the two silver battery and camera connections underneath.
    • Gently lift the connections off using tweezers.
  5. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 5、 3の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 5、 3の画像 2 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 5、 3の画像 3
    • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
    • Locate the volume control connector on the left side of the motherboard. Gently lift the silver connector off with a pair of tweezers.
    • Continuing up the left side of the motherboard, locate the white power button connector. Disengage the beige lock on the top of the connector by flipping it up with a pair of tweezers. Gently pull the wire from the connector using the tweezers.
    • Continuing along the top of the motherboard, disconnect the white LCD connection by disengaging the beige lock and pulling the wire out with tweezers.
  6. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 6、 3の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 6、 3の画像 2 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 6、 3の画像 3
    • Continuing to the right along the top of the motherboard, the next wire connects to the motherboard in two places. First, gently lift pry off the gold connector on the right with a pair of tweezers, then use the tweezers to disengage the brown lock on the black connector to the left. Use the tweezers to gently pull out the wire.
    • The final black connector is located on the right side of the motherboard. Disengage the brown lock and pull out the wire with tweezers.
  7. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 7、 1の画像 1
    • Locate the blue and red coiled wire coming from the top right of the motherboard and follow it to the round metal component. Gently pry out the component with a metal spudger. It is held down by some adhesive.
    • A flat head screw driver was used in the picture but you should use a metal spudger if possible.
  8. Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 8、 2の画像 1 Lenovo Yoga Tab 3 8 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the six 2mm screws holding down the motherboard using a JIS00 screwdriver.
    • Lift out the motherboard with your fingers.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nicklaus Krems
メンバー登録日: 09/25/17
1,067 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S16G2
4 メンバー
16のガイドは作成済み
4件のガイドコメント
I got it thanks to your instruction. Now I hope to find a new motherboard AND to get it reconnected again. I’m abit worried about the small flat wires to get them located and connected properly again. My motherboard doesn’t work anymore because I was foolish enough to flash a wrong software.
Charo Kikwalo - 返信
sir,
how to buy
please contact detail .. please
Uma sankar patnaik - 返信
Sir, where I can buy motherboard and how much price for this ?
Mazadar Entertainment - 返信
Hi,
Can you please answer the question in the forum. You can reply here also. I wanted to know the component detail my tabs component is burnt.
https://forums.lenovo.com/t5/Yoga-Book-A...
Amey - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 42
今までの合計 3,637
