メインコンテンツにスキップ
Lenovo Yoga Tab 3 8 Kickstand Lock Replacement
必要な工具と部品
  1. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: 手順 1、 3の画像 1 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: 手順 1、 3の画像 2 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: 手順 1、 3の画像 3
    この手順で使用する道具:
    購入する
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 2、 1の画像 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 3、 3の画像 1 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 3、 3の画像 2 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 3、 3の画像 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Kickstand Lock: 手順 4、 1の画像 1
    • Locate the four 2mm screws that secure the lock and remove them with a PH00 screwdriver.
  5. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 5、 2の画像 1 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: 手順 5、 2の画像 2
    • Pry the lock up with a metal spudger. There is adhesive holding the mechanism down. Carefully separate it using even pressure.
終わりに
作成者
4人の作成者と共同で作成されました。
Nicklaus Krems
メンバー登録日: 09/25/17
1,049 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S16G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 895
