メインコンテンツにスキップ
Lenovo Yoga C930-13IKB Fingerprint Reader Replacement
必要な工具と部品
  1. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Back Cover: 手順 1、 1の画像 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 2、 2の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 2、 2の画像 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 3、 2の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 3、 2の画像 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Battery: 手順 4、 3の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Battery: 手順 4、 3の画像 2 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Battery: 手順 4、 3の画像 3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 5、 1の画像 1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 6、 2の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 6、 2の画像 2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Fingerprint Reader: 手順 7、 2の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement, Fingerprint Reader: 手順 7、 2の画像 2
    • Remove the single 2 mm screw from the fingerprint reader cover plate using the Phillips #00 screwdriver.
    • Gently lift and slide out the cover plate using a pair of angled ESD tweezers.
  8. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 8、 2の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 8、 2の画像 2
    • Using the angled ESD tweezers, gently lift the black tab on top of the ZIF connector on the fingerprint reader.
    • Gently pull the ribbon cable out from the connector using the tweezers.
  9. Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 9、 3の画像 1 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 9、 3の画像 2 Lenovo Yoga C930-13IKB Fingerprint Reader Replacement: 手順 9、 3の画像 3
    • Lift and remove the fingerprint reader from the laptop using the angled ESD tweezers.
終わりに
作成者
2人の作成者と共同で作成されました。
Elizabeth Miller
メンバー登録日: 09/20/21
220 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 198
