メインコンテンツにスキップ
Lenovo Yoga 920-13IKB Screen Replacement
必要な工具と部品
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: 手順 1、 3の画像 1 Lenovo Yoga 920-13IKB Screen Replacement, Screen: 手順 1、 3の画像 2 Lenovo Yoga 920-13IKB Screen Replacement, Screen: 手順 1、 3の画像 3
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: 手順 2、 3の画像 1 Lenovo Yoga 920-13IKB Screen Replacement: 手順 2、 3の画像 2 Lenovo Yoga 920-13IKB Screen Replacement: 手順 2、 3の画像 3
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: 手順 3、 2の画像 1 Lenovo Yoga 920-13IKB Screen Replacement: 手順 3、 2の画像 2
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: 手順 4、 3の画像 1 Lenovo Yoga 920-13IKB Screen Replacement: 手順 4、 3の画像 2 Lenovo Yoga 920-13IKB Screen Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: 手順 5、 1の画像 1
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: 手順 6、 2の画像 1 Lenovo Yoga 920-13IKB Screen Replacement: 手順 6、 2の画像 2
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: 手順 7、 1の画像 1
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: 手順 8、 1の画像 1
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: 手順 9、 1の画像 1
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: 手順 10、 1の画像 1
  11. Lenovo Yoga 920-13IKB Screen Replacement: 手順 11、 1の画像 1
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: 手順 12、 1の画像 1
    • Remove the ribbon cable from the connector to detach the screen from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Alyssa McCulloch
メンバー登録日: 01/24/19
1,906 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019人のメンバー
CPSU-WHITE-W19S2G3
4 メンバー
29のガイドは作成済み
5 件のコメント
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - 返信
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - 返信
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - 返信
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 38
今までの合計 5,563
