はじめに
If your Lenovo Yoga 720-15IKB (88YG7000828) is not recognizing any wireless signals or having trouble connecting to Wi-Fi, use this guide to replace the wireless adapter. For more information on these symptoms, refer to the troubleshooting guide.
To complete this repair you’ll need a Torx T5 and a Phillips #0 screwdriver.
必要な工具と部品
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
