はじめに
This guide shows you how to replace the Lenovo Yoga 720 15-IKB (88YG7000828) speakers. This laptop is very similar to the Lenovo Yoga 720 13-inch , the Yoga 710, and the Yoga 730. Faulty speakers can cause audio to either be distorted or the computer to not produce audio at all. These symptoms are further explained on the troubleshooting page.
必要な工具と部品
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Here are the speakers for this device.
Pull the right speaker straight up and remove it from the computer.
ある他の人がこのガイドを完成しました。
