必要な工具と部品
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Use a Torx T5 screwdriver to remove the eight 8mm screws holding the touchpad in place.
ある他の人がこのガイドを完成しました。
