メインコンテンツにスキップ
Lenovo Yoga 710-15ISK Motherboard Replacement
必要な工具と部品
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 2、 1の画像 1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: 手順 3、 2の画像 1 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: 手順 3、 2の画像 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: 手順 6、 1の画像 1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 7、 1の画像 1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 8、 2の画像 1 Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 8、 2の画像 2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: 手順 9、 1の画像 1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 10、 2の画像 1 Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 11、 1の画像 1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: 手順 12、 1の画像 1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 13、 3の画像 1 Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 13、 3の画像 2 Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 13、 3の画像 3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: 手順 14、 1の画像 1
    • Carefully lift out the motherboard to remove it from the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Annette Limoges
メンバー登録日: 10/25/21
181 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022人のメンバー
UMASSD-SINCLAIRE-S22S7G1
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 259
