はじめに
Use this guide to remove or replace the battery on your Lenovo Yoga 710 laptop.
必要な工具と部品
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
20 の人々がこのガイドを完成させました。
7 件のコメント
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - 返信
Thank you making this guide for a battery replacement!
envykiss99 - 返信
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - 返信
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Worked great. thx
John Smith - 返信
