メインコンテンツにスキップ
Lenovo Yoga 710-11ISK Trackpad Replacement
必要な工具と部品
  1. Lenovo Yoga 710-11ISK Trackpad Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device having the bottom panel facing you.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 710-11ISK Trackpad Replacement, Removing back cover: 手順 2、 1の画像 1
    • Remove the back panel carefully.
    • To remove the back cover, there are 5 plastic snap hooks that must be dislodged with a spudger or plastic pick tool.
    • Lay the device upside down with hinges away from you. Tilt it at 45 degree angle, leaving hinges down and open the screen slightly. Apply a little pressure on one corner to see where it separates. Then work from side to side to separate the back case from the top case. The back case is a shell with no components in it.
  3. Lenovo Yoga 710-11ISK Trackpad Replacement: 手順 3、 2の画像 1 Lenovo Yoga 710-11ISK Trackpad Replacement: 手順 3、 2の画像 2
    • Remove the two 3mm Phillips #1 screws that are holding the battery to the device.
    • Hold the bundled cable connector on each side and carefully pull the connector to release it from the motherboard.
  4. Lenovo Yoga 710-11ISK Trackpad Replacement: 手順 4、 1の画像 1
    • Remove the battery carefully from the device by lifting up the edge nearest you and then gently pull toward you to disconnect the power wires.
  5. Lenovo Yoga 710-11ISK Trackpad Replacement, Trackpad: 手順 5、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located at the top of the trackpad.
  6. Lenovo Yoga 710-11ISK Trackpad Replacement: 手順 6、 1の画像 1
    • Remove the trackpad from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Richard
メンバー登録日: 02/18/21
241 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 119
