メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will show you how to replace the wifi card. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
パーツ
パーツは指定されていません。
  1. Flip the laptop so that the back panel is facing up. Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Gently lift the back cover off of the laptop.
    • Gently lift the back cover off of the laptop.
  3. Push the black battery cable towards the battery to disconnect it. Push the black battery cable towards the battery to disconnect it.
    • Push the black battery cable towards the battery to disconnect it.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the six #0 3.8mm Phillips screws from the battery. Remove the six #0 3.8mm Phillips screws from the battery.
    • Remove the six #0 3.8mm Phillips screws from the battery.
  6. Gently lift the battery out of the laptop chassis.
    • Gently lift the battery out of the laptop chassis.
  7. Using the plastic opening tool, gently pry the grey wire off the wifi card. Pry the black wire off the wifi card.
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  8. Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  9. Gently lift and pull the wifi card out. Gently lift and pull the wifi card out.
    • Gently lift and pull the wifi card out.
終わりに
2 の人々がこのガイドを完成させました。
Aaron Rice
メンバー登録日: 2017年04月10日
343 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G6, Forte Spring 2017 Cal Poly, Team S13-G6, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 14
今までの合計 985
