メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The tools needed to replace the USB Port in the Lenovo Yoga 3 Pro are T5 Torx screwdriver, PH0, and a spudger.
  1. Remove the eleven 6mm T5 Torx screws from the back case.
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop. Gently lift the backing off the laptop. Gently lift the backing off the laptop.
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Remove the four 3mm PH#0 screws surrounding the battery.
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop. Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop. Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Take out the 3, 3mm screws from the left hinge using the PH0 head. Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Using the tweezers, carefully lift the black clip and remove the electrical ribbon. Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
Matthew Victores
メンバー登録日: 2016年09月28日
581 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 3-2, Passmore Fall 2016 USF Tampa, Team 3-2, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S3G2
4 メンバー
7のガイドは作成済み
2 件のコメント
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 1,605
