はじめに
If your device is overheating or gets hot quickly, it might be time replace the cooling fan.
必要な工具と部品
Remove the two 3mm screws using the PH#0 screwdriver head.
Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
