メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
If you are experiencing low to no sound coming from the speaker even when the volume is turned all the way up, then you have come to the right place as your speaker may need to be replaced. This guide will help you achieve the removal and replacement of your speaker.
  1. Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Remove the two 3 mm Phillips #00 screws securing the battery. There are arrows on the battery indicating the location of the screws. There are arrows on the battery indicating the location of the screws.
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Use a pair of tweezers to gently disconnect the battery connector.
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Use a pair of tweezers to gently disconnect the speaker cable. Remove the wires from underneath the battery tabs using the tweezers.
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  6. Carefully remove the battery from the device.
    • Carefully remove the battery from the device.
  7. Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires. Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  8. Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free. Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  9. Remove the two 2 mm Phillips #0 screws securing the left speaker. Remove the two 2 mm Phillips #0 screws securing the right speaker. Remove the two 2 mm Phillips #0 screws securing the right speaker.
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  10. Use a pair of tweezers to disconnect the speaker connector. Gently lift the speakers free of the device.
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
終わりに
ある他の人がこのガイドを完成しました。
Slade Fernandes
メンバー登録日: 2015年08月27日
487 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S2G3
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 772
