メインコンテンツにスキップ
Lenovo Yoga 3 11 Motherboard Replacement
必要な工具と部品
  1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Motherboard Replacement, Battery: 手順 2、 3の画像 1 Lenovo Yoga 3 11 Motherboard Replacement, Battery: 手順 2、 3の画像 2 Lenovo Yoga 3 11 Motherboard Replacement, Battery: 手順 2、 3の画像 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Motherboard Replacement: 手順 3、 1の画像 1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Motherboard Replacement: 手順 4、 2の画像 1 Lenovo Yoga 3 11 Motherboard Replacement: 手順 4、 2の画像 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Motherboard Replacement: 手順 5、 1の画像 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Motherboard Replacement: 手順 7、 1の画像 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Motherboard Replacement: 手順 8、 1の画像 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Motherboard Replacement: 手順 9、 1の画像 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Motherboard Replacement: 手順 10、 1の画像 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Motherboard Replacement: 手順 11、 3の画像 1 Lenovo Yoga 3 11 Motherboard Replacement: 手順 11、 3の画像 2 Lenovo Yoga 3 11 Motherboard Replacement: 手順 11、 3の画像 3
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Motherboard Replacement: 手順 12、 3の画像 1 Lenovo Yoga 3 11 Motherboard Replacement: 手順 12、 3の画像 2 Lenovo Yoga 3 11 Motherboard Replacement: 手順 12、 3の画像 3
    • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card and SSD up and out of the device.
  13. Lenovo Yoga 3 11 Motherboard Replacement: 手順 13、 1の画像 1
    • Remove the three black 2 mm Phillips #00 screws.
    • Remove the single silver 4 mm Phillips #00 screw.
  14. Lenovo Yoga 3 11 Motherboard Replacement: 手順 14、 1の画像 1
    • Gently lift the motherboard up and out of the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chandler Morris
メンバー登録日: 08/27/15
172 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S2G3
4 メンバー
11のガイドは作成済み
コメント 1 件
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 15
今までの合計 7,336
