このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
9 の人々がこのガイドを完成させました。
5 件のコメント
Thanks for the great tutorial! Any part number you can provide for this?
I recently replaced my Lenovo Yoga 2 pro touch display, it was cracked and touch went crazy, the crack was from the side which made it usable by disabling the touch drivers. After a while i decided to replace the screen and get back the touch feature. but now i'm suffering that i cannot use it in tablet mode for the following reasons:
After screen replacement, when lid is closed it thinks that it is in tablet mode and screen stays on and doesn't go to sleep mode as it was before replacement, while if I put it in tablet position screen goes off and it goes to sleep mode thinking it is in closed lid position (i think). if i just lift it up only 2 mm from tablet position it gets back on.
Please advise !!
I tried following these steps in reverse order, but I cant get step 7. I can get the glass placed correctly, but cant get it to slide back into place. Do you have any suggestions to get this step working?
My Y2P camera periodically disconnects when I move the screen at the hinges. Any idea if that cable is replaceable without replacing the screen?
Can you advise on how to replace the leftmost LCD cable on Yoga 2 Pro with digitizer (touch) ?
