メインコンテンツにスキップ
Lenovo Yoga 2 Pro Screen and Digitizer Replacement
必要な工具と部品
  1. Lenovo Yoga 2 Pro Screen and Digitizer Replacement, Screen and Digitizer: 手順 1、 1の画像 1
    • Open the laptop and remove the two screw covers on either side of the computer near the hinges using either the tip of a flathead screwdriver or a spudger.
  2. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 2、 1の画像 1
    • Remove the revealed two 3/16” screws using a Phillips #00 screwdriver.
  3. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 3、 1の画像 1
    • Lift the two plastic bezel pieces off using a spudger.
    • Using a prying tool such as a spudger, gently lift the long plastic bezel piece away from the screen.
    • Be certain to only pry the plastic piece off, not anything under it. There are fragile components beneath it.
  4. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 4、 1の画像 1
    • Remove the three 1/8” screws using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 5、 1の画像 1
    • Gently remove the circuit board and set it aside.
  6. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 6、 1の画像 1
    • Remove the last 1/8” screw near the middle of the screen using a Phillips #00 screwdriver.
  7. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 7、 1の画像 1
    • Slide the screen up away from the hinges and lift from the backplate.
  8. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 8、 1の画像 1
    • Fold the screen over and disconnect the LCD screen cable by lifting up the blue tab and pulling.
  9. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 9、 1の画像 1
    • Remove the four 1/8” screws using a Phillips #00 screwdriver from the hinge on either side of the laptop.
  10. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 10、 1の画像 1
    • Using a Torx T5 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  11. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 11、 1の画像 1
    • Gently lift off the back cover.
  12. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 12、 1の画像 1
    • Remove the four 3/16” screws from the top of the laptop near the hinges using a Phillips #00 screwdriver.
  13. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 13、 1の画像 1
    • Using a metal spudger, lift up the connector by the plastic near the top.
    • The connector lifts out of the computer, do not pull it to the sides.
  14. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: 手順 14、 1の画像 1
    • Carefully remove the hinges and remove the screen.
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Thomas Simko
メンバー登録日: 10/01/15
2,511 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S12G14
5 メンバー
12のガイドは作成済み
5 件のコメント
Thanks for the great tutorial! Any part number you can provide for this?
Dana Drummond - 返信
I recently replaced my Lenovo Yoga 2 pro touch display, it was cracked and touch went crazy, the crack was from the side which made it usable by disabling the touch drivers. After a while i decided to replace the screen and get back the touch feature. but now i'm suffering that i cannot use it in tablet mode for the following reasons:
After screen replacement, when lid is closed it thinks that it is in tablet mode and screen stays on and doesn't go to sleep mode as it was before replacement, while if I put it in tablet position screen goes off and it goes to sleep mode thinking it is in closed lid position (i think). if i just  lift it up only 2 mm from tablet position it gets back on.
Please advise !!
Hussein Raouf - 返信
I tried following these steps in reverse order, but I cant get step 7. I can get the glass placed correctly, but cant get it to slide back into place. Do you have any suggestions to get this step working?
Brittany Ann Kos - 返信
My Y2P camera periodically disconnects when I move the screen at the hinges. Any idea if that cable is replaceable without replacing the screen?
Dylan Justice - 返信
Can you advise on how to replace the leftmost LCD cable on Yoga 2 Pro with digitizer (touch) ?
Oyvind Overby - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 72
今までの合計 37,366
