この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will explain how to safely remove a specific key from the keyboard of your Lenovo Yoga 2 13". It will provide a list of the tools needed as well as the easiest way to remove the key.
必要な工具と部品
ある他の人がこのガイドを完成しました。
4 件のコメント
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
