メインコンテンツにスキップ
Lenovo Yoga 2 13" Keyboard Keys Replacement
必要な工具と部品
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 手順 1、 2の画像 1 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 手順 1、 2の画像 2
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: 手順 2、 1の画像 1
    • To insert a new key, simply place and apply pressure until it snaps into place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nichelle
メンバー登録日: 03/11/15
1,550 ポイント
5のガイドは作成済み
チーム
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015人のメンバー
MARS-LAFLEN-S15S1G2
3 メンバー
7のガイドは作成済み
4 件のコメント
this doesn't fix a non-working electric contact, does it?
Simon - 返信
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - 返信
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - 返信
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 17,529
