メインコンテンツにスキップ
Lenovo Yoga 2 13" Hinge Bracket Fix
必要な工具と部品
  1. Lenovo Yoga 2 13" Hinge Bracket Fix, Back Panel: 手順 1、 1の画像 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Hinge Bracket Fix: 手順 2、 1の画像 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 手順 3、 3の画像 1 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 手順 3、 3の画像 2 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 手順 3、 3の画像 3
    • The video connector can be pulled out with the attached noose. Pull gently possibly supported by lifting the connector with a screwdriver.
    • The other connector can be pushed out on the sides with the help of a screwdriver.
  4. Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: 手順 4、 2の画像 1 Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: 手順 4、 2の画像 2
    • Unscrew three screws to detach the hinge from the body.
  5. Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 手順 5、 3の画像 1 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 手順 5、 3の画像 2 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 手順 5、 3の画像 3
    • Peel out a small plastic cover, pull out center cover and unscrew left and right cover below the display.
  6. Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 手順 6、 3の画像 1 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 手順 6、 3の画像 2 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 手順 6、 3の画像 3
    • Once the two screws are loosened, the whole display can be shifted up - don't just pull it away.
    • On reassembly, put the display and cover together slightly shifted, and then gently slide the display back into position.
  7. Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 手順 7、 3の画像 1 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 手順 7、 3の画像 2 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 手順 7、 3の画像 3
    • The hinge is attached to the lid with four screws.
    • A cable runs through each hinge, you can just pull out the small rubbery holder.
    • Loosen the screw below it to open the hinge.
  8. Lenovo Yoga 2 13" Hinge Bracket Fix, Adjustening the hinge stiffness.: 手順 8、 1の画像 1
    • The stiffness of the hinge can be adjusted by loosening the small nuts. One eighth of a turn might be enough - you will have to repeat adjusting them until the hinge has the right stiffness.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sven Meier
メンバー登録日: 05/01/16
291 ポイント
1ガイドが承認済み
16 件のコメント
Many thanks. Thumbs up!
Simon - 返信
Hi,
Thanks you for your guide. It is amazing but i worry that remove Display guide is not too clear and user may broken the LCD before he stiffness the hinges.
Kim Son
Kim Son Vu - 返信
Can you post the fix for how to tighten hinges for Lenovo IdeaPad Yoga 13 ?
Siva Nasanakota - 返信
what type of nuts are showing in last step? those are hexagonal nuts but with what size?
Wara - 返信
Just followed this howto on my Yoga 2 13: the size of the bolts is 4.5. I know because I only have 4 and 5 sized tools, and they didn't fit. I used pliers too, it works.
Stéphane L -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 55
今までの合計 19,020
