メインコンテンツにスキップ
Lenovo Yoga 2 11" 20428 Motherboard Replacement
必要な工具と部品
  1. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 手順 1、 3の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 手順 1、 3の画像 2 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 手順 1、 3の画像 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 2、 1の画像 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 手順 3、 3の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 手順 3、 3の画像 2 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 手順 3、 3の画像 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 4、 1の画像 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 5、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 5、 2の画像 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 6、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 6、 2の画像 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Hard Drive: 手順 7、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
  8. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 8、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 8、 2の画像 2
    • Lift the hard drive up, turn it over, and remove the connection.
  9. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Speaker: 手順 9、 1の画像 1
    • Use the Phillips #000 screwdriver to unscrew the four 1.7 mm screws.
  10. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 10、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 10、 2の画像 2
    • Carefully detach the speaker wire and remove the speaker.
  11. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Bluetooth Module: 手順 11、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 12、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 12、 2の画像 2
    • Gently grab and remove the Bluetooth module.
  13. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Motherboard: 手順 13、 1の画像 1
    • Using your finger nail or a thin pry tool, unlock and remove the three cables.
    • Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
    • Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
  14. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 14、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 14、 2の画像 2
    • Gently pull the cable out of the connector.
  15. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 15、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 15、 2の画像 2
    • Lift the wide cable in the center to reveal the port for the small cable underneath.
    • Using a fingernail or a thin pry tool, lift the white bar to release the cable.
    • Remove the cable from the connector.
  16. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 16、 1の画像 1
    • Lift the tape up to separate it from the motherboard.
    • Using a fingernail or a thin pry tool, lift the connector upwards to separate from the motherboard.
  17. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 17、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 17、 2の画像 2
    • Remove the black tape covering the connector.
    • Pull straight backwards to remove the connector from the motherboard.
  18. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 18、 1の画像 1
    • Pull the cable straight backwards to remove it.
  19. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 19、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 19、 2の画像 2
  20. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 20、 2の画像 1 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 20、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the seven 3.6mm screws.
  21. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 手順 21、 1の画像 1
    • Lift and pull backwards to remove the motherboard.
終わりに
作成者
7人の作成者と共同で作成されました。
Bavly Shehata
メンバー登録日: 03/30/22
181 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-3, Harley Spring 2022 IUPUI, Team 1-3, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S1G3
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 13
今までの合計 613
