メインコンテンツにスキップ
Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement
必要な工具と部品
  1. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: 手順 1、 3の画像 1 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: 手順 1、 3の画像 2 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: 手順 1、 3の画像 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 2、 1の画像 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: 手順 3、 3の画像 1 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: 手順 3、 3の画像 2 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: 手順 3、 3の画像 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 4、 1の画像 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 5、 2の画像 1 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 5、 2の画像 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 6、 2の画像 1 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 6、 2の画像 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Bluetooth Module: 手順 7、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  8. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 8、 2の画像 1 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: 手順 8、 2の画像 2
    • Gently grab and remove the Bluetooth module.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Joshua Thomas Tyler
メンバー登録日: 03/18/19
687 ポイント
5のガイドは作成済み
チーム
University of Memphis, Team S1-G2, Kim Spring 2019 University of Memphis, Team S1-G2, Kim Spring 2019人のメンバー
UM-KIM-S19S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 912
