メインコンテンツにスキップ
Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement
必要な工具と部品
  1. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: 手順 1、 2の画像 1 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: 手順 1、 2の画像 2
    • Unscrew and take out 10, 1/5 cm screws.
    • Unscrew and take out 1, 1 inch screw.
    • I use a piece of tape sticky side up to place screws on, also I label it where they go.
  2. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: 手順 2、 3の画像 1 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: 手順 2、 3の画像 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: 手順 2、 3の画像 3
    • With the vents facing away from your body I find it easiest to start at the bottom right corner first and gently pry up the corner using a plastic tool.
    • Then slide and pry the plastic tool to the left corner.
    • Then work on the sides.
  3. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: 手順 3、 3の画像 1 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: 手順 3、 3の画像 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: 手順 3、 3の画像 3
    • Carefully lift up on the back panel.
    • The back will snap out of place but be careful and don't force it to hard.
  4. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: 手順 4、 2の画像 1 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: 手順 4、 2の画像 2
    • Pull the battery cable out of it's connector. Gripping the wires in the middle gently wiggling the wires back and forth while pulling.
    • With the battery connector out.
  5. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: 手順 5、 3の画像 1 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: 手順 5、 3の画像 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: 手順 5、 3の画像 3
    • Note the tabs on each side of the RAM holder,
    • With your fingers or the plastic tool gently move the tabs away from the RAM, the RAM should pop up when both sides or moved.
    • Grip the RAM by the sides and lift out.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Corbin Schon
メンバー登録日: 01/26/16
593 ポイント
2のガイドは作成済み
コメント 1 件
Thank you for the guide! It helped me to feel sure about the disassemble.
cacalo219 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 26
今までの合計 3,739
