はじめに
This guide will walk you through with replacing the fan of your device. You're going to need to sit down and unscrew a lot of screws to access the fan of your device.
必要な工具と部品
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
この手順で使用する道具:Tweezers$4.99
Using a pair of blunt tweezers, disconnect the fan from the motherboard.
Remove the fan from the device.
もう少しです!
終わりに
コメント 1 件
What kind of fan is that?
I need to know what to order for replacement.
