メインコンテンツにスキップ
Lenovo Y410P Motherboard Replacement
必要な工具と部品
  1. Lenovo Y410P Motherboard Replacement, Removal of Bottom Panel: 手順 1、 2の画像 1 Lenovo Y410P Motherboard Replacement, Removal of Bottom Panel: 手順 1、 2の画像 2
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P Motherboard Replacement, Removal of Hard Drive: 手順 2、 2の画像 1 Lenovo Y410P Motherboard Replacement, Removal of Hard Drive: 手順 2、 2の画像 2
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P Motherboard Replacement, Remove Optical Drive: 手順 3、 3の画像 1 Lenovo Y410P Motherboard Replacement, Remove Optical Drive: 手順 3、 3の画像 2 Lenovo Y410P Motherboard Replacement, Remove Optical Drive: 手順 3、 3の画像 3
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P Motherboard Replacement, Remove Keyboard and Cables: 手順 4、 2の画像 1 Lenovo Y410P Motherboard Replacement, Remove Keyboard and Cables: 手順 4、 2の画像 2
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P Motherboard Replacement: 手順 5、 1の画像 1
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P Motherboard Replacement, Removal of Palm Rest: 手順 6、 3の画像 1 Lenovo Y410P Motherboard Replacement, Removal of Palm Rest: 手順 6、 3の画像 2 Lenovo Y410P Motherboard Replacement, Removal of Palm Rest: 手順 6、 3の画像 3
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P Motherboard Replacement, Removal of Motherboard: 手順 7、 3の画像 1 Lenovo Y410P Motherboard Replacement, Removal of Motherboard: 手順 7、 3の画像 2 Lenovo Y410P Motherboard Replacement, Removal of Motherboard: 手順 7、 3の画像 3
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
    My y410p can't start, overheat in some are in motherboard
    Fauzy Sadland - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Eric Chen
メンバー登録日: 01/22/15
868 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G21
4 メンバー
6のガイドは作成済み
コメント 1 件
there are 2 screws near the battery lock that you need to remove when removing the palm rest
JM - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 18
今までの合計 8,217
