メインコンテンツにスキップ
Lenovo Y410P LCD Replacement
必要な工具と部品
  1. Lenovo Y410P LCD Replacement, Removal of Bottom Panel: 手順 1、 2の画像 1 Lenovo Y410P LCD Replacement, Removal of Bottom Panel: 手順 1、 2の画像 2
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P LCD Replacement, Removal of Hard Drive: 手順 2、 2の画像 1 Lenovo Y410P LCD Replacement, Removal of Hard Drive: 手順 2、 2の画像 2
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P LCD Replacement, Remove Optical Drive: 手順 3、 3の画像 1 Lenovo Y410P LCD Replacement, Remove Optical Drive: 手順 3、 3の画像 2 Lenovo Y410P LCD Replacement, Remove Optical Drive: 手順 3、 3の画像 3
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P LCD Replacement, Remove Keyboard and Cables: 手順 4、 2の画像 1 Lenovo Y410P LCD Replacement, Remove Keyboard and Cables: 手順 4、 2の画像 2
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P LCD Replacement: 手順 5、 1の画像 1
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P LCD Replacement, Removal of Palm Rest: 手順 6、 3の画像 1 Lenovo Y410P LCD Replacement, Removal of Palm Rest: 手順 6、 3の画像 2 Lenovo Y410P LCD Replacement, Removal of Palm Rest: 手順 6、 3の画像 3
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P LCD Replacement, Removal of Motherboard: 手順 7、 3の画像 1 Lenovo Y410P LCD Replacement, Removal of Motherboard: 手順 7、 3の画像 2 Lenovo Y410P LCD Replacement, Removal of Motherboard: 手順 7、 3の画像 3
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
  8. Lenovo Y410P LCD Replacement, Detach LCD assembly from main Frame: 手順 8、 1の画像 1
    • Detach the LCD assembly by unscrewing four M2.5x4mm Phillips Screws. (Two on each side).
    • Pull the LCD assembly away from main frame.
  9. Lenovo Y410P LCD Replacement, Unscrew Bezel (plastic frame around the LCD Screen): 手順 9、 2の画像 1 Lenovo Y410P LCD Replacement, Unscrew Bezel (plastic frame around the LCD Screen): 手順 9、 2の画像 2
    • Using a flat head screwdriver, wedge out two plastic tabs to reveal the screws.
    • One tab is in the bottom left corner and one is in the bottom right corner. Symmetrical locations.
    • Using a #0 phillips screwdriver, unscrew two silver M2.5x4mm screws.
    • These are located underneath the previously removed plastic tabs.
  10. Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 手順 10、 3の画像 1 Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 手順 10、 3の画像 2 Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 手順 10、 3の画像 3
    • Unclip the latches at each bottom corner. They are located below the screws that were previously removed.
    • Place your fingers inside of the edge of the bezel. Separate the bezel by pulling it away from the back cover. Pull until one side has been lifted.
    • Use the same technique to separate all remaining sides of the bezel.
    • Starting at one corner and making your way around. Ensure the bezel is completely removed from the back cover.
    • Completely remove bezel from LCD screen and back cover.
  11. Lenovo Y410P LCD Replacement, Unscrew LCD Screen (Part 1): 手順 11、 2の画像 1 Lenovo Y410P LCD Replacement, Unscrew LCD Screen (Part 1): 手順 11、 2の画像 2
    • Unscrew the four M2.5x4mm Phillips screws. One screw is located at each corner.
  12. Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 手順 12、 3の画像 1 Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 手順 12、 3の画像 2 Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 手順 12、 3の画像 3
    • Gently lift the LCD screen and flip it over.
    • On back of the LCD screen, locate the protective tape in the bottom right corner. Peel off the tape to reveal a latch with a connector cable.
    • Flip the latch so that the connector cable can be removed. Remove the connector cable by pulling downwards.
    • The old LCD is now completely disconnected and you are ready to install a new LCD screen.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brandon
メンバー登録日: 01/22/15
527 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G21
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 5,685
