メインコンテンツにスキップ
Lenovo Vibe Z2 Pro Charging Assembly Replacement
必要な工具と部品
  1. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 手順 1、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 手順 1、 2の画像 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 2、 1の画像 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 3、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 3、 2の画像 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 4、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 4、 2の画像 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 5、 1の画像 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: 手順 6、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: 手順 6、 2の画像 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 7、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 7、 2の画像 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 8、 1の画像 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 9、 3の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 9、 3の画像 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 9、 3の画像 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 手順 10、 3の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 手順 10、 3の画像 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 手順 10、 3の画像 3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 11、 3の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 11、 3の画像 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 11、 3の画像 3
    この手順で使用する道具:
    購入する
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 12、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 12、 2の画像 2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 13、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 13、 2の画像 2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 14、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 14、 2の画像 2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 15、 2の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 15、 2の画像 2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 16、 1の画像 1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 17、 3の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 17、 3の画像 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 17、 3の画像 3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Charging Assembly & Headphone Jack: 手順 18、 1の画像 1
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  19. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 19、 3の画像 1 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 19、 3の画像 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 手順 19、 3の画像 3
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bryan Sepulveda
メンバー登録日: 09/15/16
547 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 18-3, Blackwell Fall 2016 USF Tampa, Team 18-3, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S18G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 9
今までの合計 1,015
