はじめに
This guide will solve issues involving a defective battery, such as: Unexpected Shutdown, Laptop not Charging, Laptop Shuts down when Unplugged.
必要な工具と部品
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
この手順で使用する道具:Tweezers$4.99
Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
Remove the battery from the device.
To reassemble your device, follow the instructions on Step 3.
2 の人々がこのガイドを完成させました。
