メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo Thinkpad x230 Screen Module Replacement
必要な工具と部品
  1. Lenovo Thinkpad x230 Screen Module Replacement, Preparations: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Screen Module Replacement, Locate the battery: 手順 2、 1の画像 1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Screen Module Replacement, Unlock the left switch: 手順 3、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Unlock the left switch: 手順 3、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, Unlock the left switch: 手順 3、 3の画像 3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Screen Module Replacement, Remove the battery: 手順 4、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Remove the battery: 手順 4、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, Remove the battery: 手順 4、 3の画像 3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Screen Module Replacement, Locate the hard drive enclosure: 手順 5、 1の画像 1
    • Locate the hard drive enclosure (marked by the red rectangle).
  6. Lenovo Thinkpad x230 Screen Module Replacement, Remove enclosure: 手順 6、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Remove enclosure: 手順 6、 2の画像 2
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the hard drive enclosure cover.
    • The screw is designed to remain within the plastic cover. Don't worry about extracting it completely.
    • Carefully remove the hard drive enclosure cover.
  7. Lenovo Thinkpad x230 Screen Module Replacement, Remove SSD/hard drive: 手順 7、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Remove SSD/hard drive: 手順 7、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, Remove SSD/hard drive: 手順 7、 3の画像 3
    • Gently pull the black pull tab out from above the hard drive. Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  8. Lenovo Thinkpad x230 Screen Module Replacement, Remove plastic rails: 手順 8、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Remove plastic rails: 手順 8、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, Remove plastic rails: 手順 8、 3の画像 3
    • Remove the plastic rails from the old SSD/hard drive and place them on the new SSD/hard drive.
  9. Lenovo Thinkpad x230 Screen Module Replacement, remove screws: 手順 9、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, remove screws: 手順 9、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, remove screws: 手順 9、 3の画像 3
    • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
    • Once you have located the two screws, remove them with a small Phillips screwdriver.
  10. Lenovo Thinkpad x230 Screen Module Replacement, remove strip above keyboard: 手順 10、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, remove strip above keyboard: 手順 10、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, remove strip above keyboard: 手順 10、 3の画像 3
    • This step is not required.
    • Gently pull the strip out from the case.
  11. Lenovo Thinkpad x230 Screen Module Replacement, pop keyboard out of the casing: 手順 11、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, pop keyboard out of the casing: 手順 11、 2の画像 2
    • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
  12. Lenovo Thinkpad x230 Screen Module Replacement, lift keyboard: 手順 12、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, lift keyboard: 手順 12、 2の画像 2
    • Carefully lift the keyboard so that you can access its connector.
  13. Lenovo Thinkpad x230 Screen Module Replacement, Unplug keyboard: 手順 13、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Unplug keyboard: 手順 13、 2の画像 2
    • Carefully unplug the connector by pulling.
  14. Lenovo Thinkpad x230 Screen Module Replacement, done: 手順 14、 1の画像 1
    • You are done - the keyboard is not connected to the laptop any more and can be replaced.
  15. Lenovo Thinkpad x230 Screen Module Replacement, Screen Module: 手順 15、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement, Screen Module: 手順 15、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement, Screen Module: 手順 15、 3の画像 3
    • Remove five 5.7mm screws from the bottom.
  16. Lenovo Thinkpad x230 Screen Module Replacement: 手順 16、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 16、 2の画像 2
    • Unscrew two 5.7mm screws from the top of the bottom of the laptop.
  17. Lenovo Thinkpad x230 Screen Module Replacement: 手順 17、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 17、 2の画像 2
    • Pull the palm rest off the laptop board.
  18. Lenovo Thinkpad x230 Screen Module Replacement: 手順 18、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 18、 2の画像 2
    • Unlock the white seal and disconnect the blue cable.
  19. Lenovo Thinkpad x230 Screen Module Replacement: 手順 19、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 19、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement: 手順 19、 3の画像 3
    • Carefully disconnect blue and red cables and remove them from plastic case.
  20. Lenovo Thinkpad x230 Screen Module Replacement: 手順 20、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 20、 2の画像 2
    • Unlock white seal and diconnect blue cable from upper corner.
  21. Lenovo Thinkpad x230 Screen Module Replacement: 手順 21、 2の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 21、 2の画像 2
    • Remove two 4.1mm screws from the black frame.
  22. Lenovo Thinkpad x230 Screen Module Replacement: 手順 22、 3の画像 1 Lenovo Thinkpad x230 Screen Module Replacement: 手順 22、 3の画像 2 Lenovo Thinkpad x230 Screen Module Replacement: 手順 22、 3の画像 3
    • Carefully pull off black frame from laptop board.
  23. Lenovo Thinkpad x230 Screen Module Replacement: 手順 23、 1の画像 1
    • Carefully lift the screen module straight up to detach from board.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lino Virgen
メンバー登録日: 10/10/16
1,062 ポイント
3のガイドは作成済み
チーム
Texas Tech, Team 6-3, Bennett Fall 2016 Texas Tech, Team 6-3, Bennett Fall 2016人のメンバー
TTU-BENNETT-F16S6G3
4 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 28
過去 30 日: 96
今までの合計 12,610
