メインコンテンツにスキップ
Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement
必要な工具と部品
  1. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Bottom Panel: 手順 1、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Bottom Panel: 手順 1、 2の画像 2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 2、 1の画像 1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 手順 3、 3の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 手順 3、 3の画像 2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 手順 3、 3の画像 3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 4、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 4、 2の画像 2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 5、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 5、 2の画像 2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 6、 1の画像 1
    • Lift each speaker up and out from the computer.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 手順 7、 3の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 手順 7、 3の画像 2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 手順 7、 3の画像 3
    • Carefully lift the far end of the battery connector with an opening tool facing towards you.
    • Remove the connector by pushing it forward and lifting.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 8、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 8、 2の画像 2
    • Remove the central 5 mm screw with a Phillips #1 screwdriver.
  9. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 9、 1の画像 1
    • Lift the battery up and out of the computer.
  10. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Fingerprint Press Scanner: 手順 10、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Fingerprint Press Scanner: 手順 10、 2の画像 2
    • Lift the black hinge that is on top of the ribbon connector using the iFixit pick.
  11. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 11、 2の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 11、 2の画像 2
    • Lift the purple ribbon connector up and out.
    • There are small plastic tabs that prevent the ribbon connector from being pulled horizontally out.
  12. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 12、 1の画像 1
    • Remove the two 2.5 mm black screws on the fingerprint scanner with a Phillips #1 screwdriver.
  13. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 13、 3の画像 1 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 13、 3の画像 2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 手順 13、 3の画像 3
    • Gently lift the right edge up of the fingerprint scanner up and slide the scanner to the right before lifting.
終わりに
作成者
2人の作成者と共同で作成されました。
Alexander Davis
メンバー登録日: 01/23/20
1,093 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020人のメンバー
CPSU-WHITE-W20S1G4
3 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,790
