必要な工具と部品
Docking via 3 pcs. connectors sliding sideways into the laptop.
Power connector used is the square type.
Keep track of where the screws are located, because there are many.
Be careful on disassembly. The dock is partly mechanical, and it relies on springs and flexing of mechanical parts to function.
Check if the firmware is updated. In this case, the repair may not be needed. The dock needs to be powered and laptop docked when running the update tool.
Use plastic picks or a metal spudger to pry off the top left corner of the shown cover. Remove the hidden screw.
Lock engaged (LED on). The switch is located inside the button assembly.(when the slider is moved right).
Laptop connected/detected: LED on.
Screw for removing the key-lock. No need for removal if the whole button assembly is to be removed together.
Use plastic picks or a metal spudger to pry off the top covers of the two screws on the top side.
PCB top side
Red boxes : Dual Synchronous, Step-Down Controller with 5-V and 3.3-V LDOs. Texas instruments: TPS51225
Left step down produce 5V
Right step down: produce 3V3 and 5V
There are three Eeprom on board : winbond: 25x10CLNIG , 8 pin, U4 and U10 (1M-bit SPI)
VLI marked IC: Via labs Usb port controllers VL820. https://www.via-labs.com/product_show.ph...
Synaptics VMM5322.Have features for HDMI and 2xDisplay port out.
PCB bottom side
Red boxes : usb-c controller ICs. Via Labs inc, : VP225 - USB Type-C DFP CC Controller
Blue box: 2 pcs. cypress CYP3123 USB type C port controller. https://www.cypress.com/part/cypd3123-40...
Red arows: 20V path to the laptop usb-c charge power.
4 の人々がこのガイドを完成させました。
