メインコンテンツにスキップ
Lenovo Thinkpad Twist s230u Upper Casing Replacement
必要な工具と部品
  1. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: 手順 1、 2の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: 手順 1、 2の画像 2
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 2、 1の画像 1
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 3、 1の画像 1
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 4、 2の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 4、 2の画像 2
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Keyboard: 手順 5、 1の画像 1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 6、 1の画像 1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 7、 1の画像 1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 8、 3の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 8、 3の画像 2 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 8、 3の画像 3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Upper Casing: 手順 9、 1の画像 1
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 10、 2の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 10、 2の画像 2
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 11、 2の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 11、 2の画像 2
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 12、 2の画像 1 Lenovo Thinkpad Twist s230u Upper Casing Replacement: 手順 12、 2の画像 2
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Arthur McPeak
メンバー登録日: 01/14/20
682 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 914
