メインコンテンツにスキップ
Lenovo Thinkpad Tablet 1838 Speaker Replacement
必要な工具と部品
  1. Lenovo Thinkpad Tablet 1838 Speaker Replacement, Speaker: 手順 1、 1の画像 1
    • Remove the middle button by putting a plastic spudger or your fingernail underneath the button and lifting up.
  2. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 2、 1の画像 1
    • There will be two screws under the button you have removed. Use your Phillips #00 Screwdriver to remove these screws.
  3. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 3、 1の画像 1
    • With a plastic spudger or your fingernail, find the seam where the front and back panel connect and pry open from the bottom. After making a small opening, go around the device counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 4、 1の画像 1
    • Before you separate the panels, there is a ribbon cable connecting the LCD to the motherboard. To avoid damage of the ribbon cable, lift the panel with the LCD from right to left like opening a book.
  5. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 5、 2の画像 1 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 5、 2の画像 2
    • This is the speaker unit, and is being held by a screw. Use a Phillips #00 Screwdriver to remove the screw indicated by the red circle in the second image.
  6. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 6、 2の画像 1 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 6、 2の画像 2
    • The speaker is still connected to the motherboard by a little connector. Using a plastic spudger or your fingernail, pry the connector to the direction marked by the two red arrows in the second image.
  7. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 手順 7、 1の画像 1
    • After removing the connector, you can now remove the speaker. Use your spudger or fingernail to lift the speaker up. The speaker should come out easily.
終わりに
作成者
2人の作成者と共同で作成されました。
Arturo Barboza
メンバー登録日: 10/26/17
209 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G2, Riccardelli Fall 2018 University of North Texas, Team S1-G2, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 151
