メインコンテンツにスキップ
はじめに
Use this guide if either your power or volume buttons have stopped working or if you just want to clean them.
パーツ
パーツは指定されていません。
  1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: 手順 1、 1の画像 1
    • Remove the button on the front of the tablet that has the arrow pointing to the left .
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 2、 1の画像 1
    • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
  3. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 3、 1の画像 1
    • Use a plastic spudger to pry open the screen from the tablet.
    • Work around the perimeter of the tablet going counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 4、 1の画像 1
    • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 5、 1の画像 1
    • To peel back the ribbon connector, first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  6. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 6、 1の画像 1
    • Remove the screw that is highlighted.
    • Use a size #00 Philips head screwdriver.
  7. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 7、 1の画像 1
    • Remove the blue motherboard the screw was attached to.
    • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
  8. Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 8、 3の画像 1 Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 8、 3の画像 2 Lenovo Thinkpad Tablet 1838 Button Replacement: 手順 8、 3の画像 3
    • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
    • While the tabs are pushed in the buttons should pop out.
終わりに
Dylan Coleman
メンバー登録日: 2018年09月21日
157 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G2, Riccardelli Fall 2018 University of North Texas, Team S1-G2, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 19
今までの合計 239
