メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Remove the button with the arrow pointing left.
    • Remove the button with the arrow pointing left.
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Remove these two 10mm screws with a Phillips head screwdriver using the #00 bit.
    • Remove these two 10mm screws with a Phillips head screwdriver using the #00 bit.
  3. Use a plastic Spudger to pry open and disconnect the screen from the rest of the tablet.
    • Use a plastic Spudger to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet counterclockwise.
  4. Open the tablet screen to the left. Making sure not to disconnect any of the wires connecting the screen and tablet.
    • Open the tablet screen to the left. Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. Peel back the rubber tape strip from the battery.
    • Peel back the rubber tape strip from the battery.
  7. To peel back the ribbon connectors first gently open the white gates.
    • To peel back the ribbon connectors first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  8. After you have opened the white gates just simply pull out the ribbon connectors.
    • After you have opened the white gates just simply pull out the ribbon connectors.
    • Peel them back so they are not sticking to the battery.
  9. Remove the four 5mm screws that I am pointing to with the metal tools.
    • Remove the four 5mm screws that I am pointing to with the metal tools.
    • Use a Phillips head screwdriver using the #00 bit.
  10. Disconnect this connector I am pointing to.
    • Disconnect this connector I am pointing to.
    • Remove it gently with your fingers pulling towards the battery.
  11. Simply remove the old battery carefully.
    • Simply remove the old battery carefully.
まとめ
Michael Gaskey
メンバー登録日: 2018年09月28日
337 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G2, Riccardelli Fall 2018 University of North Texas, Team S1-G2, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G2
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 26
今までの合計 308
